Subject: Re: Peel coat film for protecting cabinets long-term
1/24/23
Matt Member
Some of our installs are large multi-family units that may go 6 months or more between cabinet install and move-in day for the eventual tenants.
Our finish is conversion varnish. Are there any peelcoat type films (rolls of plastic, not spray-on) anyone suggest that won't harden or wreck the color/sheen of the cabinets?
I know it won't protect it from granite guys ramming 400 pounds of stone into it, but it will help reduce the number of reworks we eventually get.
How does cabinet wrap from places like WURTH hold up after 6 months?
2/5/23       #3: Peel coat film for protecting cabin ...
MarkB Member
Id be really cautions of any type of peel film without a ton of testing on your finish and process. I, and probably everyone, have had thr nightmare of trying to peel those off that have eithet been on too long or are maybe too aggressive and it winds up being a nightmare to get off. Cant help but to think perhaps ordering sheets or rolls of corrugated and just shrink warapping or taping it on after install would give you better all around protection. Just my $0.02
5/15/23       #4: Peel coat film for protecting cabin ...
bekeanloinse Member
Website: https://subway-surfers.io/home
WURTH offers cabinet wraps that can provide temporary protection. While I couldn't find specific information on how these films hold up after six months, they are generally designed for short-term use during transportation, installation, or construction. It's advisable to reach out to the manufacturer or read customer reviews to gather more insights on the durability of their specific product.
5/29/23       #5: Peel coat film for protecting cabin ...
Likan
Proper application is crucial for the longevity of the cabinet wrap. Follow the manufacturer's instructions carefully, ensuring the film is applied smoothly and without any bubbles or wrinkles. Proper adhesion will help the film stay in place and protect the cabinets effectively.
7/10/23       #6: Peel coat film for protecting cabin ...
Marilian
Website: https://run3online.io
Since these films are meant for temporary usage during transit, installation, or building, I was unable to discover any information about how they held up after six months. If you want further information on the product's longevity, you should contact the manufacturer or look at customer reviews.
7/14/23       #7: Peel coat film for protecting cabin ...
Ross Wells Member
Website: https://fgtcabinetry.com/
When choosing a peel coat film for your kitchen cabinets, it is important to consider the following factors:
The type of cabinets you have: If you have unfinished cabinets, you will need a film that is designed for unfinished surfaces. If you have finished cabinets, you can use any type of film.
The level of protection you need: If you want the most protection possible, you should choose a thicker film. If you are just looking for some basic protection, a thinner film will be sufficient.
The ease of application: Some films are easier to apply than others. If you are not comfortable with DIY projects, you should choose a film that is easy to apply.
2/8/25       #10: Peel coat film for protecting cabin ...
poki
You might want to look into 3M's Surface Protection Films or WURTH’s cabinet wrap, as both are designed for long-term protection without damaging finishes. Many contractors have had good results with WURTH’s film, even for extended periods, but it's always best to test a small area first.
Since you're using conversion varnish, make sure the adhesive on the film is low-tack to avoid any reaction with the finish. Also, avoid exposure to high heat or humidity, as some films may become harder to remove over time.
Has anyone else here left protective film on for 6+ months? Would love to hear real-world experiences!
3/13/25       #11: Peel coat film for protecting cabin ...
LionModApk
Great question! For long-term protection, I’ve heard that some peel-coat films like those from 3M could work well without compromising the finish. WURTH cabinet wraps have a solid reputation for durability, but it might be good to test on a small area first to make sure it doesn’t affect the sheen or color. Definitely agree that any extra protection is a game-changer for reducing reworks later on!
3/18/25       #12: Peel coat film for protecting cabin ...
IG to MP4
Great post! It’s always helpful to find durable solutions for protecting cabinets during long-term installs. As for the peel coat films, I’ve heard good things about products from WURTH, but it's always worth testing on a sample to ensure it doesn't affect the finish. By the way, if you’re into Instagram content, VidInsta is a fantastic tool for downloading videos, reels, photos, and stories from Instagram, and you can even convert them from IG to MP4. Perfect for saving and organizing your favorite posts!
3/24/25       #13: Peel coat film for protecting cabin ...
friv games
Could you specify the model of your Holzher edge bender? I can help guide you through tightening the pad chains if I know which one you're working with.
    • CabMaster Software
    • Steve H. Wall Lumber Co.
    • WalzCraft
