Subject: Re: Inside Corner Drawer Movento Undermout Installation
12/2/23
Brandon Member
I'm installing my first dovetail inside corner drawers. Question is positioning the tandem under mounts for inset drawers. I've install many Blum under mount where I've made my drawers to there spec in regards to length and with of the drawer boxes. Do I install a 1/2" thick x inside width backing for the locking clip inline with the inside corner of the drawer box? Attached are the two cabinets I've built.
Thank you in advance for help.
Corner_Cab_1_3D.pdf
right_side_cabinet_1.pdf
left_side_view_cabinet_1.pdf
KitchenCabinet Inside Corner Drawers
12/4/23       #2: Inside Corner Drawer Movento Underm ...
Josh Koschak
Yes, your drawer length is arbitrary. Position the new blocking at the same distance from the back as a normal drawer. The guides will then just be installed further back in to the cabinet to accommodate the new front geometry of the drawer.
12/4/23       #3: Inside Corner Drawer Movento Underm ...
Brandon Member
THANK YOU FOR THE RESPONSE.
12/5/23       #4: Inside Corner Drawer Movento Underm ...
brent
Here are blums instructions for the corner drawers. This is for the angled fronts which use the 27" glides. If its a flat front just make it that way and use 30" glides with a 30" drawer box. You will use the corner block that is stated in the drawings for the clip, which just simulates the flat front of the drawer box.
space_corner_construction.pdf
12/5/23       #5: Inside Corner Drawer Movento Underm ...
Brandon
Fantastic. Just what I was looking for.
Thank you
4/3/25       #6: Inside Corner Drawer Movento Underm ...
omegle Member
Website: https://omegleweb.io/
Getting those dovetail inside corner drawers perfect can be tricky! When positioning your tandem undermounts for inset drawers, especially with Blum hardware you're accustomed to, consider mirroring the Blum specs. Adding that 1/2" backing for the locking clip, inline with the drawer box's inside corner, sounds right. It’s like using Omegle - connecting two precise points for a perfect fit. Anyone else have experience with this specific setup?
