Subject: Re: Wood vertical strips accent wall
12/7/24
Andrew
I am planning to make an accent wall- paint wall black them attach 2”wide vertical that are 8’-0” long 3/4” maple Veneer wood with 3/4” space between each strip. Should influence wood strips to the wall? I am trying to avoid using nails on the 3/4” veneer strips. Another option was to paint a 1/4” sheet of veneer wood black then glue 3/4” strips and attached a few screws from the back. Not quite sure what would be the method to create this accent wall- wall is 15’-0” wide
12/9/24       #2: Wood vertical strips accent wall ...
chris
Website: https://www.csaw.com/lamello/
Morning Andrew,
Several of our Lamello P-System customers have found a clever way to build slat walls with our connectors. See link for our application card on this.
https://www.csaw.com/wp-content/uploads/2024/09/Slat-Wall.pdf
    • WalzCraft
    • CabMaster Software
    • Steve H. Wall Lumber Co.
