Subject: Re: Installing Storewall HD slotwall panels
5/21/13
Rich  Member
Any one have experience installing onsite Storewall HD plastic slotwall panels in a running bond pattern?
What is the best way to cut the 15 1/4" wide material? I borrowed a friend's sliding miter saw, but it is only good for a 12" cut. I could use a straight edge clamp and cut it upside down with a cordless circular saw. Or would I be better off renting a SMS with a bigger stroke? Will probably need to make 50 or so cuts for the job. Any other suggestions? I will be using installSTRIPS to hang the Storewall on. And I will be installing trim to hide the cuts.
5/21/13       #2: Installing Storewall HD slotwall pa ...
Chris
for onsite I would use a track saw. like a festool. worth every cent and then some.
you could also get the festool work table which allows the track to flip up and down to perform 90 degree cuts.
12/23/13       #3: Installing Storewall HD slotwall pa ...
paul enos
festol ?. if your going to go that rout then get the vac and arm to.2K plus tax that will only cost you $ 40 per cut. any panel or skill saw and track will work fine.
6/11/25       #4: Installing Storewall HD slotwall pa ...
Daniel Member
I’ve installed Storewall HD panels a few times, and for that many cuts, a track saw like Festool with a proper vac setup is ideal—clean, accurate, and less mess on-site. If you don’t have one, a circular saw with a guide clamp works, just go slow to avoid melting the plastic. Trim pieces will definitely help disguise imperfect edges.
    • WalzCraft
    • CabMaster Software
    • Steve H. Wall Lumber Co.
