Detached toe kicks
7/5/16
Ken Member
Website: http://www.artisanbilt.com
Doing my first commercial job and plan to use detached toes. My real question(s) is in regards to how leaving the proper height for the vinyl (rubber) base to go on afterwards. First, if (which it will be) the floor is out of level then do I make the max height 4" and scribe for the high spots or can I just shim the low spots? I would think that this second option would be ok for all the areas that have a set back toe but what about the finished end panels? My plan is to do a "mini-toe" set back maybe 1". If this end gets shimmed up to higher than 4" then that leaves a gap above the vinyl base. Depending on the amount this may or may not be an issue. Just wondering what the standard/best practice is? Also, do I need to account for carpet height?
7/6/16       #4: Detached toe kicks ...
james mcgrew Member
depends on drop and length , appliances Etc. on older high rises we have seen dips of 1.5" and more,
recently had a hotel with a 1.75" drop over 12 feet. had UC refridgerators so we had to inform gc we could not scribe as refers were on the low side. Best tool for this is a self leveling laser,
as well we set our cross members in the ladderback a 1/2" shorter than the rails, this gives as much as an inck of scroive if needed.
7/6/16       #5: Detached toe kicks ...
MarkB Member
An inck of scroive is the bare minimum. (love it).
7/6/16       #6: Detached toe kicks ...
james mcgrew Member
i COULD USE SPELL CHECK FER SUR
7/6/16       #7: Detached toe kicks ...
MarkB Member
*hicup**
8/31/16       #8: Detached toe kicks ...
Chris
I second the notion, Hiccup. No really, 1- 1 1/2" over 12 feet is kinda normal from what I've seen commercially. I've always set the base at 4" off the floor and whatever difference is what it is....5 3/4 on the trailing end...
