Backsplash caulking pulling away from countertop
2/4/20
Derek Member
Hey all,
We recently got a call-back about the backsplash caulking pulling away from the countertop. In this case, it was a new construction home. I understand there are many variables that could have caused this. Anything from framing shrinkage to not using enough cabinet fasteners. Does anyone have any tips for trying to bulletproof this in the future? Should we be gluing the shims to our toekicks, screwing blocks to level the toekick instead of shims, using more fasteners in the cabinet back?
Thanks for any help.
Derek
2/5/20       #2: Backsplash caulking pulling away fr ...
Gluing shims is a waste of time.
You’ve got at least 4 kinds of cabinets:
Classic face frame integrated toe kick Ladder base with applied toe kick
Euro style with 4 legs clip on toe kick
Hybrid style is cleat on wall 2 legs in front
You should be screwing into every single stud you can find.
2/5/20       #3: Backsplash caulking pulling away fr ...
pat s gilbert
Normally the backsplash is screwed to the counter. For a formica counter that is, if this is a closet that may be overkill
If you shim the toe kick gluing the shims or screwing a block to the sleepers is typical for good reason.
2/12/20       #4: Backsplash caulking pulling away fr ...
Derek Member
Thanks guys
2/15/20       #5: Backsplash caulking pulling away fr ...
Keith Newton
Did I miss where you stated what the counter top is made of?
If it was a solid wood / butcher block, it would be obvious that shrinkage across the grain, but you probably already know that.
I'm wondering if you used a solid wood base that may have had a high moisture content. When it dried, the front may have dropped down enough to tilt forward a bit if the fasteners through the cleats were away from the box ends. I would check for level front to back, and if the height of the toe kick has changed.
2/17/20       #6: Backsplash caulking pulling away fr ...
Dave Edgerton  Member
We use silicone on the bottom face of the backsplash and small dabs to adhere to the wall. You are adhering to the wall too much. Also is there laminate on the back side of the splash?
11/26/20       #7: Backsplash caulking pulling away fr ...
I personally use Tower Tech caulk. The black tube for better quality and the blue lettering tube is to paint it within 30 min. Both of them work very well. They have a very high elasticity, which will allow great expansion and contraction without cracking
    • CabMaster Software
    • Steve H. Wall Lumber Co.
    • WalzCraft
