Diewall Install methods
5/28/20
Gary Member
Just curious how others are installing fabricated walls for reception desks, etc. I'm in favor of a double bottom plate (one removable to attach to the floor). Are others shimming this level at the concrete, or just fastening it to the concrete, then shimming between it and the bottom wall plate as needed, then screwing into the floor plate.
I feel like it may be better to shim at the concrete, then throw some foam insulation under it at the gaps. Then I'm working with a level surface moving forward, but I'm interested in hearing how others are doing it.
5/29/20       #2: Diewall Install methods ...
james e mcgrew  Member
Answer is "All of the Above" A desk has some money in it so it should be right. Allways a good idea to prescope a site with a self leveling laser to check whether a deck should be prefloated level by G/C
We always assemble the bottom plate, go to job site and paint it located on the deck (Take photos) We then drive in removable pins to relocate,,, G/C supervisors are more often just Glorified Order takers with Little Actual construction experience.
5/29/20       #3: Diewall Install methods ...
Alan F. Member
If the wall can have a "loose" finish kick we leave a space to slip it up into the wall. Sometimes we use removable back panels so it can push against the cleat and then install from the front.
Larger walls / desks are too hard to lift over the cleat and scribe in many situations. Depends on the design
9/23/20       #4: Diewall Install methods ...
cabinetmaker
We just tap con them in place and let the flooring sub come to us and vinyl, tile or whatever is called for
    • Steve H. Wall Lumber Co.
    • CabMaster Software
    • WalzCraft
