PUSH OPEN CATCH
1/2/21
Jim Clark Member
I have a customer who wants "push to open"
hardware on his cabinet doors. everything
I've tried takes way more pressure than the
hinge has to close the door.
I even tried these rated for self close hinges,
"TIP-ON for Self/Soft Close Hinges White Blum 956A1006" and they too won't let the door close. Do any of you know of a latch
that will work?
1/3/21       #2: PUSH OPEN CATCH ...
Craig Caughlan Member
Website: wetimber.mx
One option is to use the short version Blum Tip-On 956 w/ magnet and an unsprung Blum hinge. Depending on the cabinet, I'm not a big fan as the push/release gap takes the door(s) out of plane with the cabinet.
On another note, I would like to know if a push/release soft close hinge exists. I don't think so.
1/3/21       #3: PUSH OPEN CATCH ...
mastercabman Member
I don't think you'll find any
Tip-on you will need to push it close
Another thing that makes it worse is that most hinges used this day are soft close so not enough energy for the door to push that tip on in the close position
1/3/21       #4: PUSH OPEN CATCH ...
mastercabman Member
I like to add
Maybe contact BLUM and see if they offer something better than their standard Tip on
The Tip on for drawers works like you're looking for
You push it to open then when you push the drawer to close it, it closes with soft close with no problems
1/17/21       #5: PUSH OPEN CATCH ...
Jim,
Have your seen the Salice Push hinges? The self-opening feature is built into the hinge then the door is held closed and activated to open by a magnet. Push hinges are available with opening angles of 94 degree, 110 degree and 155 degree. Here is a link to our web site. You will find all of the details here.
Best of luck,
Dennis Bean
Salice America
View higher quality, full size image (945 X 750)
Salice Push Hinges
1/17/21       #6: PUSH OPEN CATCH ...
Jim Clark
Thanks Dennis-that should work
    • CabMaster Software
    • Steve H. Wall Lumber Co.
    • WalzCraft
