Install over carpet?
9/20/17
Chris Member
When you install into a space that is carpeted (e.g. a bookcase in a carpeted bedroom), do you remove the carpet where the cabinet rests or install the cabinet on top of the carpet? If you remove the carpet, do you install new tack strips around the cabinet and restretch the carpet?
9/20/17       #2: Install over carpet? ...
Chris Member
Please excuse my oversight... If I had searched the forum before posting this question, I would have found this has been discussed at length in the past.
Chris
9/20/17       #3: Install over carpet? ...
Kip  Member
Website: covenantcustomcabs.com
Go and sin no more
5/7/21       #4: Install over carpet? ...
DianaFallon Member
I have made a deep floor restoration, and even changed the carpets. I know that it was a little bit more expensive than we planned in the beggining, but at least everything looks nice and clean now. I hope that this floor will look decent at lest for 5 years (minimum!) and that deep cleaning will be enough! If you think that you want that too than here you go: https://primeflooddamagerestoration.com.au/ check them out and see if you like them or not. or just call them 0480 022 665
    • WalzCraft
    • CabMaster Software
    • Steve H. Wall Lumber Co.
