Lazy susan on a table
10/20/21
Post
I have a client that I am building a 72" round oak table for. They want to add a 38" lazy susan to the center of it. Id like to make it so the lazy susan is removable for cleaning. So you can lift up one side and clean underneath. Any ideas for attachment to allow for this and also any suggestions for a quality mechanism as the only one I've used is on a round table that I finish chairs on.
10/20/21       #2: Lazy susan on a table ...
duster
Large diameter bearings for this purpose are available from Amazon and other retailers. If the the top surface of the lazy susan is supposed to be flush with the table top, you'll have to route a pocket for the bearing and lazy susan. Easy to do with a cnc, otherwise you'll need to build a jig to do it. If you want to make it easily removable for cleaning, I'd route a deeper ring for just the bearing, so that it's captured and will stay centered on the table. That way it can easily be lifted off and replaced.
10/27/21       #3: Lazy susan on a table ...
Jim
One work of caution.
Factor in keeping the turntable flat.
Back finish and steel reinforcement plate attached to the bottom.
O just repaired one done by another shop.
Cost of repair was fairly substantial
It was on a 72 inch diameter turntable though
    • Steve H. Wall Lumber Co.
    • CabMaster Software
    • WalzCraft
