Need advice on mechanical contractors
11/12/22
Brian Member
I am a Florida cabinet installer that works with a designer and a cabinet wholesaler, all independent from each other. My contract states that I don't do any mechanicals such as plumbing, electric or appliance installation. The problem I'm having is with homeowners asking me for an electrician, plumber and backsplash installer as they don't have their own. In every case the homeowners have complained about the these contractors bills and get upset when they hit the smallest of snags. I've got uncompensated time in scheduling and don't like assuming responsible for others, if I did in my mind that would make me a GC. Question; how do you all handle the mechanical contractors on your kitchen remodels?
11/16/22       #2: Need advice on mechanical contracto ...
Just walk away from it if you dont have anyone you can recommend in good conscience. As you said, if your not making a markup off them as a sub whats the point? The only thing you could do is have a list of 3-4 companies to hand to a customer and say theses are just some companies Ive seen on other jobs but have no idea.
I'd just get away from it if its as your post states. If they are coming back at you saying "you told me xyz and they screwed me".. stop giving any recommendations.
11/29/22       #4: Need advice on mechanical contracto ...
Brian Member
Thanks for your reply, Mark. I like your suggestion of handing a list with multiple contractors and then letting them decide
12/7/22       #5: Need advice on mechanical contracto ...
Joe Member
Yeah I go hands off. Like you said you're not a GC but if you start making recommendations or doing scheduling then you get treated like one! Even if I give a name out, I still tell people to get multiple quotes so they can't come to me later with complaints.
Also if part of my job will be held up by another contractor I make sure the customer knows that I won't be onsite that day or days and if they request I'm there, then they pay an houly rate for my time whether I can be productive or not. Unfortunately I've been down that road way too many times and have finally realized not to give my time away!
12/28/22       #6: Need advice on mechanical contracto ...
Brian Member
Thanks Joe, that’s wise, multiple quotes and charging for your time. Amazing how many hours can be lost on a job
7/12/23       #7: Need advice on mechanical contracto ...
FGT CABINETRY LLC (IOWA) Member
Website: https://fgtcabinetry.com/
Check with FGT Cabinetry LLC in Florida.
    • Steve H. Wall Lumber Co.
    • CabMaster Software
    • WalzCraft
