Compact table saw or something else?
12/11/22
Oggie  Member
I'm looking for some small/compact table saw that I could use inside the apartment for typical kitchen installation tasks, which in my case are 99% cutting fillers and toekicks out of 3/4" white melamine or laminated plywood stripes. Those are cut on the job site out of 2" wide stripes (for fillers) or 5" wide stripes (for toekicks) which are precut to that size in my shop, so not that much heavy cutting on the job site, just a little bit of shaping the parts that are already close to their final size.
I hope that with the help of typical shop vacuum (like DeWalt DXV08S) I could care take of most of the dust (which is main requirement) so that I could actually do the cutting inside instead of making multiple trips in and out of the apartments and up and down the stairs for each cut, in Florida weather, which is mostly either sun or rain.
Some escaping dust is inevitable and I'm ok with that.
I'm trying to find some small size table saw that would be lighter than, let's say Dewalt DW745, which I'm using now, and feel is a little too much to use inside the apartment.
I went to big box store to check the 8-1/2" Dewalt compact saw (DWE7485) on a display, and it seems almost as big and heavy as a regular 10" saw I use now, so that one probably wouldn't make much of a difference for heavy lifting and space requirements.
On the positive side, it has some elaborate fabric lining around the blade area which probably leads to decent dust control, and typically good Dewalt fence system.
Does anyone know of any other smaller and lighter table saw (or maybe some other tool or solution) of decent quality that would work well for these situations?
12/12/22       #2: Compact table saw or something else ...
Mark B
I hate festool but something like their small TS may be the best, lightest, cleanest, option if you can find/import one.
12/16/22       #3: Compact table saw or something else ...
Will Williamson  Member
Have you seen the new Makita Mitersaw that converts to a small table saw. https://www.youtube.com/watch?v=d6dQwE96DyM
12/19/22       #5: Compact table saw or something else ...
Joel D'Angelo
If I were u I wouldn't fool with an 8.25" I used to have a delta job site ts that was light as heck. The fence sucked but for a few cuts..
    • CabMaster Software
    • Steve H. Wall Lumber Co.
    • WalzCraft
