Plain slice veneer plywood
2/9/23
Andrew McIntyre Member
I am curious about Plain slice veneer and how it will look for cabinets.
I would like to build a walnut bath vanity using plain slice veneer plywood. Curious if the plain slice is the industry standard
2/11/23       #2: Plain slice veneer plywood ...
D Brown
The plain sliced veneers look more like real boards glued together as opposed to the rotary sliced which has a wider grain pattern, then there is split face which is the least attractive in my opinion..
2/11/23       #3: Plain slice veneer plywood ...
For walnut you will likely only see flat sliced or quartered walnut. Rotary I think is more often seen in birch, maple and poplar in furniture ply.
2/14/23       #4: Plain slice veneer plywood ...
Mira Sherronm
Website: https://bubble-shooters.co/
For the basic cut, a massive knife is used to slice the log while it is put on a big slicer. Each pass of the log slices one piece of veneer, much like the slicing machine at the neighborhood butcher shop slices cheese or roast beef.
    • CP Adhesives
    • American Vision Cabinets
    • Steve H. Wall Lumber Co.
    • Cabinet Pro
    • WalzCraft
    • INNERGY
