Glass-paneled cabinet door max size
8/21/23
Mike Member
Hi all. Any suggestions on the largest size of a glass paned cabinet door. I’d really like one 32 high x 24 wide but I’d suspect that would be too large and the joints would separate no matter how constructed.
Was planning to make from poplar though would also consider oak.
Thanks.
8/22/23       #2: Glass-paneled cabinet door max size ...
Hi Mike,
The size you mention does not seem unreasonable. I'm not sure what you mean by "glass paneled". If you need a recommendation for the hinges to use, I would be happy to help. There are several types of glass door hinges on the market.
Regards,
Dennis
4/2/24       #3: Glass-paneled cabinet door max size ...
Nick
Hi! Your concerns about the size of a glass paned cabinet door and the potential for joint separation are valid, especially for a door that measures 32 inches high by 24 inches wide.
