Cabinet Hardware on Dummy Drawer
11/14/23
Tom Jensen
I have a cabinet set with a row of drawers on the right and left sides. However, the drawers on the left side are faces only, since (due to the design of the room) drawers would not be able to open. So the cabinet maker simply made cosmetic drawer faces. The faces cannot be removed, so I do not have access to the inside like I would on a typical drawer.
My question is, how can I install drawer pulls on the left row of drawer faces to balance the look with the right side row of cabinets? I am using Emtek pulls that require access to the inside of the drawers to install screws. The dummy drawer faces in the left side cannot be removed for access, unfortunately.
11/15/23       #3: Cabinet Hardware on Dummy Drawer ...
nicko
maybe you could put a small diameter screw in the drawer front and then cut the head off and if needed enlarge the screw hole on the pull and epoxy them on to the screw stud.
11/15/23       #4: Cabinet Hardware on Dummy Drawer ...
Tom Jensen
Thanks. I was thinking the same thing but wanted a sanity check from someone who has done it. I think I will go ahead with your suggestion.
11/19/23       #5: Cabinet Hardware on Dummy Drawer ...
Quicktrim
Simply get screws with a wood lag on one side and a machine screw on the other . Then pre drill the fronts and thread on by hand or use a vice grip with electrical tape around the jaws.
11/23/23       #6: Cabinet Hardware on Dummy Drawer ...
Jim
For single knob I'd use a machine screw with wood threads on one end
For pulls I'd use the same machine screw with wood threads on one end, bore the threads out of the pulls and bore and tap them for set screws on the bottom side
I haven't had much luck with trying adhesive method
    • Steve H. Wall Lumber Co.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • CabinetCRUNCHER
    • Wicked Cool Tools
      Make cabinet door parts 3x faster with the UNO2
    • WalzCraft
