Installing Cabinets Against Tiled Wall
5/31/24
howard
Website: http://woodcontours.net
I am building and installing tall cabinets for a community room, around 6 feet high from the floor. They will be installed perpendicularly to a wall that will be covered with a rough limestone type tile. My question is should I have them tile the whole wall and then bring the cabinet up to the wall, or have them stop the tile at a trim board and then butt the cabinet up to the trim board? The other way I thought was to install the cabinet first and then have them tile, but that ends up concealing part of the face frame. Really appreciate your guidance with this. Thanks
7/6/24       #2: Installing Cabinets Against Tiled W ...
Sam spangler
Pack out the wall with wood the same size as your cabinet, attach to wall . Tile up to this sub frame, then add cabinets to/against a straight sub frame . Unless you want to scribe against the rock / tile.
Or make face frame on the end larger to account for thickness of rock, hang cabinet then rock up to extended width stile.
My Past experience.
9/26/24       #3: Installing Cabinets Against Tiled W ...
daivuted72 Member
That was very helpful, thank you.
