Installing flush cabinets to drywall
10/13/24
tom ruth  Member
I was wondering what the best way to install cabinet boxes before the drywall is installed, so the drywall installer can install their L metal or bead in the correct place leaving a square opening for cabinet doors? This is when you want the cabinet doors and drywall to be flush without using any scribes. I'm thinking it would be a mistake to install the cabinet doors before the drywall? Just wondering the best way to deal with this sort of installation?
10/13/24       #2: Installing flush cabinets to drywal ...
Mark
You would have to install the cabinet boxes with a fixed "plaster ground" the size of the door plus your door gap for them to fit the bead to
10/13/24       #3: Installing flush cabinets to drywal ...
tom ruth  Member
That's what I was thinking would be the only solution. Install some sort of temporary stop on the cabinet box and then they could run their drywall and "L" metal up to that. I would remove the stop and install the cabinet doors after drywall is finished.
    • CabMaster Software
    • Steve H. Wall Lumber Co.
    • WalzCraft
