Wood vertical strips accent wall
12/7/24
Andrew
I am planning to make an accent wall- paint wall black them attach 2”wide vertical that are 8’-0” long 3/4” maple Veneer wood with 3/4” space between each strip. Should influence wood strips to the wall? I am trying to avoid using nails on the 3/4” veneer strips. Another option was to paint a 1/4” sheet of veneer wood black then glue 3/4” strips and attached a few screws from the back. Not quite sure what would be the method to create this accent wall- wall is 15’-0” wide
12/9/24       #2: Wood vertical strips accent wall ...
chris
Website: https://www.csaw.com/lamello/
Morning Andrew,
Several of our Lamello P-System customers have found a clever way to build slat walls with our connectors. See link for our application card on this.
https://www.csaw.com/wp-content/uploads/2024/09/Slat-Wall.pdf
3/13/26       #4: Wood vertical strips accent wall ...
Bunczo Member
For your 15’-0” wide accent wall painted black, the best no-nails method is to directly attach the 2”-wide, 8’-0” long 3/4” maple veneer strips using heavy-duty double-sided mounting tape (like 3M VHB or Command Strips rated for 10-20 lbs per strip), applied in a zigzag pattern on the back of each strip after cleaning the wall with isopropyl alcohol for max adhesion—space strips 3/4” apart (needing about 45 strips total), starting plumb with a laser level, and press firmly for 30 seconds each. Avoid the 1/4” backer sheet option as it adds bulk, weight (risking failure), and screw visibility from behind; tape alone holds veneer securely on drywall if not overloaded, is fully removable without damage, and suits the thin profile—test one strip first, and for insurance on a high-traffic wall, add construction adhesive sparingly at ends with tape for hybrid hold.
