Edge bander tighten pad
2/5/25
Anthonyg Member
Hello all i own a holzher edge bender and i am looking to tighten the pad chains is there any one can help me with that?
View higher quality, full size image (3000 X 4000)
3/24/25       #3: Edge bander tighten pad ...
Lee Newton Member
While specific procedures can vary depending on the model, here are general steps to guide you:​ Consult the User Manual: Begin by referring to your machine's user manual, which provides detailed instructions tailored to your specific model. If you don't have a physical copy, digital versions are often available on the manufacturer's website or through authorized dealers.​
Ensure Safety: Before performing any maintenance, disconnect the machine from its power source to prevent accidental operation.​
Access the Chain Mechanism: Open the machine's service panels to locate the pad chain system. This area may be behind protective covers designed to safeguard internal components.​
Identify the Tension Adjustment Mechanism: Look for adjustment bolts or screws near the chain mechanism. These are typically used to modify the chain's tension.
3/24/25       #4: Edge bander tighten pad ...
anthony
thank you for your reply already did it there is a tighting screw i did not see it
b
    • Steve H. Wall Lumber Co.
    • CabMaster Software
    • WalzCraft
