Residue-Free Labels Latest in Tools and Supplies
Hinges
3/27/25
Nicko
I usually build face frame cabinets with half inch or full overlay doors. I have a few cabinets I'm building that are face frame with inset doors. Can anyone recommend a soft close hinge for inset? Also these doors will be 54 inches tall and 10 inch wide doors. Would you recommend 2 or 3 hinges? I’m thinking two would be good but maybe three just to keep the door supported in the middle.
Thanks.
3/28/25       #2: Hinges ...
jamien Member
Any of the big manufacturers making overlay hinges make inset ones. go with the brand you know. I use blum, but just because i know their system. All the hinges also have weight ratings you can do the math on to determine how many, but for .75-1" cabinet door i dont usually bother and put hinges on every 16-20" no matter the width (to a point). so 4 hinges on your spec'd door. More hinges give you more adjustment on tall doors in the y axis reveal if the door doesn't stay perfectly flat. 3 would work fine, but i'd put 4 on that door.
3/28/25       #3: Hinges ...
nicko
thanks for the reply
3/28/25       #4: Hinges ...
Hello Nicko,
Salice offers 2 ways to approach this.
Both are dependent on the space behind the face frame. Here is an illustration using the soft close hinge part numbers.
In method 1, the space behind the face frame will determine the mounting plate height.
Possibilities range from flush to 1-1/8" behind the frame.
In method2, there is a 9/16" space required for the mounting plate to fit.
Three (3) hinges are recommended for a 54" tall door.
Please let me know if you have any questions
Regards,
Dennis Bean
Salice America
View higher quality, full size image (1010 X 553)
4/4/25       #5: Hinges ...
Steven
Dennis,
Just out of curiosity, is there a reason why the hinge is not illustrated in the drawing for method b like it is in the drawings for method a?
4/4/25       #6: Hinges ...
Nicko,
It just happened to be the only drawing I had at the moment. Here is a more detailed drawing of method B.
Dennis
View higher quality, full size image (598 X 846)
    • WalzCraft
    • Steve H. Wall Lumber Co.
    • CabMaster Software
