Routing Color Layer off hpl
7/14/12
Leck Member
I have a project that requires routing a groove in Nevamar laminated floor tile 1/8" w x approx 1/32" d (or just the color layer). Can't find the right combination of bit type/rpm/feed rate that will give me more than 20 lf of cut before the bit fries. I've tried a laminate trimmer (30k rpm), 1 hp router (26k rpm), Freud and cmt carbide bits as well as 1/2" end mills. I'm sure the rpm has to come down, but how? This job involves approx 1,000 lf of groove, so this will get expensive quick. I know the lft grade of hpl is pretty hard, but this is crazy. Anyone have any ideas?
7/14/12       #2: Routing color layer off hpl... ...
eddie
A while back. There was a discussion about cutting laminate and what bits to use on the cnc forum. The info might help with your job.
7/15/12       #3: Routing color layer off hpl... ...
Leck Member
Thank you, Eddie. I'll dig into it and let you know how it turns out.
8/15/12       #4: Routing color layer off hpl... ...
samoen
Are the floor tiles installed already? Could you make a jig and do it on your table saw?
