Nevamar laminates
5/22/13
Bob Krauss
Website: http://www.dclweb.net
I don't know if it's just me, but it seems that I cannot trim Nevamar without having the clear melamine face chip and flake along the cut edges. I have to put masonite under pre-lam material to keep the scoring blade from crazing it back along the cut edges. Brand new blades, brand new router bits. No difference after a few feet of cutting. Any helps?
5/22/13       #2: Nevamar laminates ...
Nick
I tend to cringe when Nevamar is spec'd for a job... I've always been able to trim it with laminate trimmers and get a nice edge, but compared to all other laminates it feels like trying to cut glass. You even get the shards sandblasting any exposed skin.
Where as my new favorite, Pionite is like trimming room temperature butter. I love that stuff.
6/10/13       #3: Nevamar laminates ...
Ed Strahota  Member
Website: http://www.blackbros.com
Its "bitter-sweet" due to their proprietary ARP surface. You're basically fighting with Aluminum Oxide! It's a great surface protection, but it chews up bits, and makes it harder to get a clean finish... the link below goes to the ARP product page.
Nevamar Products
1/6/14       #4: Nevamar laminates ...
Jimmy Naylor Member
I always thought they should give files with every so-many sheets purchased too. Seriosly, I'm willing to trade off a little in this dept. because it is durable. Pionite, Laminart, and some of the other softer laminates are more of a beast to me simply because they scratch easier during fabrication. And as a added nuisance, extra care needs to be taken with these when packing for shipment. This adds up to even more man hours than we already take to protect items along with the extra packing goods and the sharpening costs actually are cheaper. As for chipping when cutting Nevamar, look at your feed rates and adjust as needed. Too slow may cause too much heat which will cause it and too fast will since the tooling is designed to do it's job at a certain feed rate range. Sometimes you just need to find the "sweet spot" for the specific material you're using.
