Sanding SS sink
1/20/14
Bruce H
We have a Wilsonart SS sink installed over ten years ago with a lot of hair line cracks on the bottom. Today we ground them out and it looks 98% better. They weren't all that deep but did have trapped dirt. Not sure exactly what caused it?
The grind out was tough because we didn't have air on the job so had to do it with electric RO. The handle is in the way.
What kind of sanders have others used for this kind of situation? Something that is all vertical and no handle. Wasn't all that tough to do but the sink bottom isn't entirely flat because we had to tilt the sander and grind on the edge. Is there something electric that will work in this tight space?
2/2/14       #2: Sanding SS sink ...
cabinetmaker
we have used the dremel or oscillating handy tools with good luck with those triangle tips.
When you are done, use Barkeepers Friend. Seals and polishes.
2/3/14       #3: Sanding SS sink ...
Adam West  Member
Our little 3" random orbital sander would be perfect for that with our swivel hose. That kind of thing is what it was made for....but it's air driven. We designed it for doing the clean up after gluing in a sink and routing to flush it up.
2/3/14       #4: Sanding SS sink ...
Bruce H
That was my problem, no air on the job. Seems like there must be something with a pad on the end, a flexible shaft might work?
3/13/14       #5: Sanding SS sink ...
Adam West  Member
In august we will have an electric sander for sale that has the same handling characteristics as our air sanders. Might be interesting for you down the road. Keep an eye on our website.
    • Anver Corporation
    • Accu-Router, Inc.
      CNC 3 and 5 Axis Routers for Wood, Composites, Plastics, and Aluminum
    • Supergrit Abrasives
    • Limtech Industries, Inc.
    • WalzCraft
    • WEIMA America, Inc.
      WEIMA America Offers Hopper-fed and Horizontal Shredders as well as Briquette Presses to Handle Wood Dust and Shavings
    • Byrd Tool
      Quality Tooling for the Woodworking Industry
    • Denray Machine
    • Country Saw & Knife
    • Seymour & Associates Inc.
      Talent Recruitment for Custom Wood Store Fixtures, Architectural Millwork, and Cabinetry Professionals
    • Impact Search and Placement
