PLASTIC LAMINATE OVER MELAMINE
1/1/21
jay solka Member
Hi
I know this was discussed before, but not in the context I would put it.
The material/labor cost for cabinets (esp that some plastic laminates cost much much more than melamine) with melamine boxes is much lower than with plastic laminate boxes. The problem: exposed surfaces such as bottoms and sides that have to have plastic laminate. Additional problem is that even if we make those sides and bottoms with plastic laminate on both sides is that the color may not match. One thing we do, we belt sand melamine before laminating. Looking for the best solution, best glue advice, or other options.
Thank you.
Jay
1/2/21       #4: PLASTIC LAMINATE OVER MELAMINE ...
MarkB Member
Why not just bring in melamine one side or layup custom panels with exposed face laminate one side and cabinet liner (color of your choice) the other side?
1/2/21       #5: PLASTIC LAMINATE OVER MELAMINE ...
pat s gilbert
Don't make the mistake of laminating melamine with laminate as it will warp
1/3/21       #6: PLASTIC LAMINATE OVER MELAMINE ...
Jeff Thomas
I'd second the recommendation to layup with cabinet liner or vertical grade on the back side. Every melamine manufacturer should be able to tell you what the Formica or Wilsonart match is for every color.
If you're working with white melamine, it is available in one sided which techinically still won't result in a balanced panel, but I haven't had any issues as long as it it glued up with contact cement.
We have also sanded melamine and laminated with contact cement. We haven't had any issues, but its not my first choice.
1/3/21       #7: PLASTIC LAMINATE OVER MELAMINE ...
Jeff Thomas
Also in the case of finished ends, we use applied panels instead of laminating the case side.
Very rarely has anyone objected to this.
1/24/21       #8: PLASTIC LAMINATE OVER MELAMINE ...
cabinetmaker
Shop around and get bids on laid up panels.
Most owners could careless on the bottom of a wall cabinet being the same as the face as long as it saves money. That’s always driven by some designer
It’s actually not that expensive to mix up panels with melamine casework.
I would highly recommend what others are cautioning about, and NOT sand and laminate the melamine
1/1/24       #9: PLASTIC LAMINATE OVER MELAMINE ...
Pravin Member
Website: https://durianlam.com/
If you're considering applying plastic laminate over melamine, it's a feasible option. The key is to ensure that the melamine surface is clean, smooth, and free from any imperfections. You may need to lightly sand the melamine to provide a better surface for adhesion.
    • CP Adhesives
    • ECabinet Systems
    • Cabinet Pro
    • Lignomat
    • Air Handling Systems
    • GreCon
    • INNERGY
