Need supplier of 1.5" radius postformed tops - Qty 700
1/5/23
Dave Keck Member
Website: http://www.Komponents.com
We can't seem to find a supplier that will do a much larger radius than the normal 3/4" countertop radius. The top is 16" deep and about 33" long and 1.5" thick. But the front 90 degree postform must be about a 1.5" radius. Quantity is over 700 tops. Very little wiggle room on the design.
1/13/23       #3: Need supplier of 1.5" radius p ...
Joe Knobbe
Dave, have you tried Counterform in Marshfield?
1/13/23       #4: Need supplier of 1.5" radius p ...
Dave Keck Member
Joe, The Marshfield countertop companies are not wanting to do it because of the large radius. But I found another Wisconsin company that will.
Thanks!
6/7/23       #5: Need supplier of 1.5" radius p ...
Jerry MOODY
I work for a solid surface wholesale and retail distributor in tennessee. We have an experienced fabrication shop along side our warehouse. Is this an acrylic .5",.75" material with a 1.5" dropped edge needing bullnosed or front needs dropped down and a bullnose applied?
If still needn help email me some pics and go from there if we can help.
6/6/24       #6: Need supplier of 1.5" radius p ...
Lola Member
Website: https://wattsan.com/
Explore custom fabrication options or specialized countertop manufacturers who can accommodate your specific radius requirements. Consider negotiating with suppliers or communicating your needs in detail to see if adjustments can be made. Additionally, reach out to industry contacts for recommendations on potential solutions. If necessary, be open to alternative design options that may still achieve your desired outcome.
    • J&P Machines
    • CabMaster Software
    • Lignomat
