Titebond Cold Press
1/3/24
Dave Member
Any of you guys use this stuff on raw wood laminate. Its really thin like watered down Titebond. Are you suppose toapply it on both surfaces. I am doing laminate repair and didnt want it to squeeze out the seams so I put it on thin on one surface but Iam not sure it will be strong enough. Regular Titebond it like iron.
4/11/24       #2: Titebond Cold Press ...
Karl Member
Website: https://wattsan.com/
Yes, you should apply it to both surfaces for optimal adhesion and strength. While it may be thinner than regular Titebond, applying it to both surfaces ensures a secure bond, especially for laminate repair. This helps prevent issues like seam squeeze-out and ensures a durable repair.
12/20/25       #3: Titebond Cold Press ...
H LC Member
Website: http://www.hlc-metalparts.com/
Haha, I've used this stuff too—it just looks unsettling. It's so runny; my first thought is always: can this really stick?
Let me briefly share my experience: This kind of thin glue doesn't rely on "thickness," but rather on penetrating. Applying it to only one side is risky, especially with composite boards, where it absorbs a lot of glue.
    • Impact Search and Placement
    • The Millwork Studio
    • Cabnetware Support
    • CabinetCRUNCHER
    • J&P Machines
    • WalzCraft
