Epoxy for Solid Surface
2/17/25
Charlie Member
What type of epoxy should I seek out for bonding Wilsonart solid surface counter material. I have some extra material from Home Depot but I don't have epoxy to bond edges and pieces together. I had a contractor install some counter and they used epoxy from a small twin tube that smelled horribly like nail polish, so I assume it was an acrylic epoxy type. The color used was an off white like "linen".
4/30/25       #2: Epoxy for Solid Surface ...
Bruce H
You can get it from a SS fabricator.
5/1/25       #3: Epoxy for Solid Surface ...
Charlie Member
I got color matched epoxy from Artisan Adhesive. The color match was way better than what the contractor had used, they used the Wilsonart product, but it may just be they used the wrong color of Wilsonart.
7/8/26       #4: Epoxy for Solid Surface ...
irtubes  Member
Website: https://irtubes.com/
Color matching is certainly important for visible joints, but long-term bond performance also depends on proper surface preparation and adhesive compatibility with the solid surface material.
A few practices that generally help improve bond durability include:
* Cleaning both bonding surfaces thoroughly to remove dust, oils, and contaminants.
* Lightly abrading the surfaces if recommended by the adhesive manufacturer to improve mechanical adhesion.
* Following the specified mix ratio and cure time without disturbing the joint during curing.
* Ensuring the adhesive is formulated specifically for solid surface materials, as these products are designed to accommodate the thermal expansion characteristics of acrylic-based sheets.
A well-prepared joint should provide both a clean appearance and reliable long-term performance under normal service conditions. It's always worth doing a small test bond when working with leftover material before making the final assembly.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • J&P Machines
    • Woodwork Career Alliance
    • Lignomat
    • Original Saw Company
      Industrial Radial Arm Saws
    • TradeJobPlacement.com
