Laminate trimming woes
11/19/25
Mike D  Member
We've started adding some laminate clad components to our offerings.
We use the trimmer bit with the Euro square bearing. Have it all dialed in and when trimming the edge it randomly burns through the surface color (on the edge) exposing white. We used laminate decades ago that seemed thicker much more forgiving. Now it's a constant redoing of parts.
Any tips on what we're doing wrong?
thanks
11/20/25       #2: Laminate trimming woes ...
james e mcgrew  Member
Use a regular trim bit and spray some lami lube or brush some Vasoline on the bearing edge
11/20/25       #3: Laminate trimming woes ...
Jim Herron
Ive used WD40 in the past but I do think the wear and color layers are thinner now and very sensitive to byrn through
11/22/25       #4: Laminate trimming woes ...
bob lee
masking tape the edge
use a solid carbide bit
remove tape
finish with bevel bearing bit
no clog/no wear through
11/25/25       #5: Laminate trimming woes ...
Jamie Hughes
Pledge will also help lower friction and reduce this effect.
