Sawing and Drying
Subject:
inaccurate miter cuts DW718
6/24/17
cooksumrice Member
i have adjusted the fence, made bevel adjustments and changed the blade.
I bought this saw recently and have since notices scuffs on the machine that suggest it was dropped.
I would like to know if this is something that can be adjusted or hacked or if I need to retire the saw to chop duty.
Makes pretty accurate 90 horizonal cuts.
problem is with 45 bevel cuts on either side.
driving me crazy.
6/25/17       #2: inaccurate miter cuts DW718 ...
David R Sochar
Your lumber does not appear to be flat. The cutoff on the right shows a 'cup' defect.
Think about it....
You must have flat and true lumber for any type of joinery.
7/3/17       #3: inaccurate miter cuts DW718 ...
Harry DeVrieze
Flat lumber is a must . However even with flat lumber a stiff sharp blade is a must. A dull thin blade will bend with the grain when fed too aggressively in to the stock. .
