Sawing and Drying
Subject:
rotted out pine core
12/31/17
john Member
has anyone seen this before core rotted to dust but not the branches
1/1/18       #2: rotted out pine core ...
john Member
trying for better pictures
View higher quality, full size image (3400 X 2550)
1/1/18       #3: rotted out pine core ...
Keith Newton
Yes, I spotted a standing tree in a yard while driving by that had been hit by lightning, maybe several times. It was open down one side, so I could see the skeleton of the younger tree inside.
The rich pine has great rot resistance, while the heartwood has low resistance, and the sapwood was still living cells, but likely to decay shortly after leaving the sapwood band into the heartwood while being exposed to this unfriendly situation.
Here is a pic. Just click on the image to enlarge it.
1/2/18       #4: rotted out pine core ...
Gene Wengert-Wood Doc
This is a technical explanation.
In order for fungi to grow and become active, they need water, warm temperatures, oxygen and food. In a loving tree, the sapwood often contains so much water that there is no oxygen. Hence, the sapwood in the living tree is not subject to decay. In some of the pines, the sapwood can exist for up to 35 yers or more. That is, no heartwood forms until the tree is over 35 years old. So, it is very unlikely that the tree had any heartwood at all. Heartwood, due to the increased amount of chemical deposits, has a food supply (i.e., the wood itself) that in pine is somewhat poisonous to fungi. However, even though the stem was all sapwood, not all sapwood is the same...the older sapwood does not have the high moisture content that younger sapwood has and therefore has oxygen. So, old sapwood is subject to decay before it converts to heartwood. The presence of decay inside a stem is therefore seen in some pine species.
The branches of a tree do have some heartwood development early in life and this means that the central part of a branch will have some decay resistance due to the poisonous wood. This heartwood forms perhaps due to stress or perhaps due to juvenile wood. The branch heartwood is not 100% decay resistant and can be small in diameter. However, such decay resistant heartwood wood in a branch is why some branches persist on a stem long after they have died. Eventually the stem grows around them and creates the "black knots" we see in pine.
1/2/18       #5: rotted out pine core ...
john Member
this tree was damaged at ground level along woodline in a housing development probably 30 years ago most likely during final grading I thought the branches were unique they are one eighth inch from touching formed during the new growth one year pretty cool
