Sawing and Drying
Subject:
winter sawing
12/8/18
Bryan "doc" Henderson  Member
Was milling an older walnut log last week and shredded a belt to the hydraulic motor. It had some cracking and was its time to go. After putting on a new belt I also thought it may have been the colder temps even though I let things warm up for 1/2 hour. So I pulled out a spare KAT magnetic block heater and put that on the side of my metal hydraulic tank and kept it at 50 degrees when 35 outside. I know some put rv antifreeze in the lube. I broke a fitting one year when the lube tank froze. What other tricks do you all use to help mill in the cold months?
12/15/18       #5: winter sawing ...
Gene Wengert-WoodDoc
As you have discovered, cold hydraulic fluid can get quite thick. Plus if there is any accidental water hiding in the fluid, it will freeze. Also, even with warm fluid, all the components and piping is cold, so when the pump is turned on, there can be thick fluid in the pipes, etc.
Two things. Use a commercial cold weather additive for the fluid. Second, is let the fluid run through the system a few times before making the equipment work hard.
12/19/18       #6: winter sawing ...
Thank you Sir. I have learned so much from you. I am still wanting to attend your courses. My sawmill manufacturer in kc is not biting. We have fewer trees in Ks. and therefore not as many people into sawing and drying. We do have a forester in town so may see if they could help get you here.
