Sawing and Drying
Subject:
Best bandsaw for resawing
1/11/19
Benny Hageman Member
Hello all. Iam in need of some advice. We recently landed a job where we are using old heart pine joist, and we need to slice off 1.25” skins. Joists are 8-12” x 8-16’ long.
I researched Cantek machinery, they have a good 5 hp bandsaw. Has anyone used them, or can point me in the right direction of a solid bandsaw. Hoping to get one in the $3500-$7000 area. Thank you!
1/11/19       #2: Best bandsaw for resawing ...
dustin orth
How many lineal feet are you looking to do? How often are you going to resaw stuff? A regular standup bandsaw would have to be outfitted with a power feeder or you are wasting your time if it's more than a few boards. I would look into a horizontal resaw like a Baker. We have one that will do 9" wide and will do it all day. You can find them used in 12" models but your going to pay a little more but worth every penny over a vertical. Only down side to these is the floor space they take up. I put mine on wheels to move around in the shop but have a cover for it to store outside to keep the elements off. I move it out there with a forklift and 6' extensions.
These are good for rough resawing at speed or veneer at slow speed and a new blade. I'd use it more often if I had floor space to keep it set up. I do have 2 vertical bandsaws inside so this isn't a one sided view .
1/12/19       #3: Best bandsaw for resawing ...
Give Woodmizer a call.
1/15/19       #4: S oprionRe: Best bandsaw for resawi ...
Gene Wengert-WoodDoc
I have seen a simple resale system from Baker where the lumber is flat on a horizontal conveyor. The band saw is set whatever distance above the conveyor you desire to give you the thickness you want. Planing dry lumber cants or flinches to a precise standard thickness before resawing can be worthwhile. In fact one mill I worked with planed the top and bottom faces of the flitch smooth and then used a Baker bandsaw to resale the flitch into two pieces. They also molded a tongue and grove into the edge so they had interior t&g paneling that had both a smooth face and a rough face- -user’s option.
