Sawing and Drying
Subject:
Standardization of Lumber Sizes
7/23/19
Leon Member
Hello, I was wondering if the bigger lumber companies on the west coast (West Fraser etc.) of Canada produced the same lengths on nominally marked lumber. For example would the 2x4s produced in their different mills all be one and a half by three and a half, or would there be variations amongst mills(random length)?
7/25/19       #3: Standardization of Lumber Sizes ...
GeneWengert-WoodDoc
All graded softwood lumber will be the same actual size, if it has the same nominal sizes, like 2x4x8’. However, this is the size measured at the time of grading. But, as the wood might change MC after grading, usually dries a bit, then size changes can result.
7/25/19       #4: Standardization of Lumber Sizes ...
Leon Member
Would it be safe to assume then that the east coast has a similar process? Would graded SPF wood for example be the same in actual size as compared to the nominal declaration
7/26/19       #5: Standardization of Lumber Sizes ...
GeneWengert-WoodDoc
Yes...all legitimate mills use the same standard. Look for the grading stamp from NeLMA, SPIB, etc. to assure you of adherence to the rules.
7/28/19       #6: Standardization of Lumber Sizes ...
GeneWengert-WoodDoc
Concerning length, there are standards that are the same in North America. However, there are special products that can have different lengths, but they would be uniform across the country, USA and Canada.
