Sawing and Drying
Subject:
white oak
9/14/19
jim volkjm j
for above ground applications which will last longer white oak or green treated pine?
9/14/19       #2: white oak ...
Grant Member
I would assume properly treated pine would outlast white oak. In what application are you using the wood?
9/14/19       #3: white oak ...
Depends what the green treated is rated at.
9/16/19       #4: white oak ...
jim volkjm j
i want to build a stairs up to my deer stand and did not know if i should saw up some 6/4 white oak or go buy some 6/4 treated pine. Not looking for the cheapest but the longest lasting
9/16/19       #6: white oak ...
Keith Newton
I built a privacy fence outside my shop 36 years ago using WOak for the pickets that are still good. Just don’t use any sapwood.
10/27/19       #7: white oak ...
GeneWengert-WoodDoc
In general, the most critical location is where two pieces of wood join. This traps water, P roperly treated pine will last longer. The chemicals are stronger than the natural chemicals found in white oak.
Any construction technique that will trap water and not let the wood dry quickly after a rain will shorten the life. A water repellent coating will do awesome things for the life of either.
Note that pressure treatments of large timbers are only for the outer two inches. The core will often have little pressure treatment chemicals. Heartwood of pine does not pressure treat. So, any time a crack or check develops in a large timber, it can expose untreated wood.
The sapwood of white oak (or any species) has little natural resistance to rot (decay) fungi.
