Sawing and Drying
Subject:
Eastern white pine for projects
12/17/20
John
Good evening to all. I have a skid of two by 4s and two by 8s of eastern white pine I milled several years ago. They have been undercover and was stickered the first couple years. Would it be ok to use the wood for an indoor project? Or should they be sanitized in a kiln?
12/20/20       #3: Eastern white pine for projects ...
rich c
If you don't care about a customer calling you about piles of frass on the floor, then air dried it is. Personally I would have it run through a kiln and then sterilize it.
1/5/21       #4: Eastern white pine for projects ...
Scott Alvik Member
Website: http://cabindoctor.com
I would get it indoors for a couple weeks at least to allow it to stabalize and to dry surface moisture. Also, running through a planer or jointer would be good
1/6/21       #5: Eastern white pine for projects ...
Not to mention Eastern White Pine will bleed sap for the next 800 years if the pitch is not set in a kiln. Sticky gloppy mess. Would be like having boards with honey spread all over them once the heat comes on in the winter. Stuff sure smells nice though.
