Sawing and Drying
Subject:
Removing sticky sawdust off SYP lumber?
5/27/21
Keith Newton
I'm normally sawing hardwood with my Woodmizer LT15 but I've had some large SYP trees blow down in a storm that I want to saw up and have pressure treated.
Since my mill is a bit short on power, the correct blades are hard to find, and the feed rate isn't fast enough to clear the chips very well. So everything I cut is packed with the sticky dust. It doesn't even sweep off with a stiff brush so I've been using a machete to scrape it off. However, I'm thinking about using a garden hose or power washer to blast if off. They can be stood to air-dry before going into the stacks.
Is there some reason not to do this?
5/27/21       #2: Removing sticky sawdust off SYP lum ...
Mark B
Have you tried ripper blades from Jerry's resharp? Man... ran a bunch of them and they were super impressive.
I'd guess the pitch is a tough one but maybe try sawing with diesel or kero instead of water? Worry would be the petro making the chips/boards more sticky but it may be worth a try. Chips may be gumming up with the water but a super light drip of diesel/kero may let them clear.
Its what Ive always done when sawing pitchy stuff like pine/hemlock. You might even try a bit in a little hand held pump sprayer or some WD40 as a test.
5/28/21       #3: Removing sticky sawdust off SYP lum ...
john kapp
call your woodmizer dealer they have a solution you can add to the lubemizer when sawing sappy wood
5/28/21       #4: Removing sticky sawdust off SYP lum ...
Mark Hineman Member
I've sawn White Pine, but not SYP. As I recall, Wood-Mizer had me add 1 to 2 cups Pine-Sol (has 8.? % pine oil) to the 2 cup vegatable oil/ 1 cup dish soap in 5 gallons.
I use the same mix when cutting utilituy poles.
    • Forestry.com
