Sawing and Drying
Subject:
Value of Pecan wood logs
2/28/22
F. Gene Arabia Member
I recently cut back a Pecan tree that I planted in 1978 and have a number of sizeable logs that I would like to sell or give away to woodworkers. How do I determine the cost and value. Where would I find interested wood workers.
I live in Yorba Linda, California. I can provide some photos. Thanks
3/2/22       #3: Value of Pecan wood logs ...
If it's in your yard, it has no commercial value. Sawmills don't like steel in trees.
3/3/22       #5: Value of Pecan wood logs ...
Rich, thanks for your response, but what is meant by saw mills don't like "steel" in trees?
3/4/22       #6: Value of Pecan wood logs ...
Yard trees have a very high likelihood of nails, bolts, eye bolts, etc. I've even hit hidden concrete in yard trees where someone had the brilliant idea that filling a rotten spot with concrete would actually do some good.
3/5/22       #7: Value of Pecan wood logs ...
Petes
You can try the wood working groups in your area. OC Turners, or Orange County Woodworkers Assoc. Some one may make a bowl for you.
3/5/22       #8: Value of Pecan wood logs ...
Gentlemen, thanks for your responses. There is no metal in my tree. I will look into local organizations that may have interest.
3/7/22       #9: Value of Pecan wood logs ...
Everybody says there is no metal in their trees. Have you lived around that tree since it was planted? If not, the likelyhood of metal goes way up.
3/8/22       #10: Value of Pecan wood logs ...
RichC.... if you read again my original post, you will see that I planted the tree from a pecan nut in 1978. I have cared for the tree since then. No metal in my wood, end of message.
3/16/22       #11: Value of Pecan wood logs ...
GeneWengert-WoodDoc
Fruit and nut trees develop, in general, lots of stress while growing and producing nuts. They branches contribute to this. Further, a yard tree has many more branches (or knots) that cause warp and appearance issues when sawing.
The bottom line is that you might be able to give the tree away, but it’s usefulness in the commercial market is very low.
The wood turner idea idea is worth exploring, but they do not like the color variations in some yard trees. Also, most years trees have bacterial wet wood that creates cracking and odor issues.
PDA. Is a very dense wood, so any sawmill or even a turner will have special issues, as sawblade must be different and tooling requires special attention.
Yard trees are know to crack more when drying the wood.
3/19/22       #12: Value of Pecan wood logs ...
Thanks to all of you for your responses regarding the pecan wood from the tree that I planted in 1978. I placed an ad in craigslist, orange county, CA for the green logs that were culled from the huge tree. I had an overwhelming response from more than 18 wood workers, carvers and artists that wanted the pecan hardwood. All of the wood was carried off in 3 days by enthusiastic people.
