Sawing and Drying
Subject:
drying a large cherry burl
2/5/23
Dietrich Hoecht
Website: http://dietrichhoecht.com
Last fall I acquired a freshly cut cherry burl and set it off ground under a loose tarp to start drying (here in North GA). This burl is roughly 26 x 22 inches and has the trunk left on both ends. I plan in the future on cutting out one or two slices and making two tables from the left-overs on a forged iron base. I want a simple method of careful drying the uncut burl, not wanting to wait five years for it. I am thinking of a wood framed box, bubble wrap insulated and a thermostat controlled fan at 120 degree setting, plus a small vent hole. 6 months drying time. Any suggestions?
2/8/23       #2: drying a large cherry burl ...
todd
There is a couple of different ways to dry it of course. Drying to fast or just drying can cause cracking. I have had good luck with cutting them in half or smaller pieces. Make sure to seal the end grain. most people use wax. i have used couple coats of oil base paint, kilz still makes oil base. Air movement is the key to drying more than heat. I have also banded the wood with straps to hold it tight. hopefully some of these tips help you out and good luck sir
    • Forestry.com
