I didn't go with the reefer body but something wider. The reefer body is awful tight with the air flow. I went with a 12' x 20' insulated metal inside and out building. I started out with DH and loading AND unloading by hand (LONG DAYS). At that time it only had double doors (6'w). After load/unload 3x......I modified and made triple 3' (9') doorway, added a track and carriage system...Added a 3'x9' knockout mechanical room for DH, fans and heat.
My circulation is set up different due to my carriage hieght (ex-farmwagon frame), the initial air flows longways under the lumber and then up through the lumber and escapes out the sides. This lets my have and use FULL advantage of my heat never having hot and cool spots (heat always rises). I have insulated panels that I place around the carriage that creates a plenum (air balancer in hvac systems) forcing balanced air up through lumber. This is a little slower for my drying due to I cut wider boards than usual and creates fewer slots...but most of mine are live edge flitches leaving larger single gaps.
Here's a few pics, enjoy and maybe it will be helpful. Have a Blessed day.
