Residue-Free Labels Latest in Tools and Supplies
Sawing and Drying
homemade kiln
11/19/14
Ricky Godfrey Member
Im new to sawmilling, and have been doing alot of reading on drying lumber, and kilns. My question is if i build a building as close to airtight asi can get it could i use a heatpump as a source for drying my lumber? It would blow warm air in and and draw it out keeping the room at a consistent
temperature. Would i need to ad a humidifier?
11/19/14       #2: homemade kiln ...
Gene Wengert-Wood Doc
Yes, yes and no.
A heat pump kiln is also called a dehumidifier. The heat is pumped back into the kiln chamber rather than exhausted to the outside.
The lumber itself will provide all the moisture that you will need with a tight building...about 4 gallons per 1% MC loss per 1000 BF.
11/19/14       #3: homemade kiln ...
Don Lewis
Website: http://nyle.com
That won't work very well or last very long. It will use a lot more energy than if you use the heat pump as a dehumidifier instead of as a heat source for a conventional heat and vent kiln .
