Sawing and Drying
safe rate for moisture removal
7/3/18
Jonathan Cook Member
I read somewhere that the safe rate of moisture removal needs to be followed until you get down to 20% Does that mean that fully air dried wood which I think should be around 20% can be kiln dried by a dummy like me with little chance of damaging it with quick moisture removal? I read that SYP safe rate is 30%, but what does that mean? It would seem like it would mean 30% of the moisture each day. Which can't be right because then it would only take a little over 3 days to dry the lumber. Can this just be measured with a meter instead of the oven drying process described in some articles?
7/4/18       #2: safe rate for moisture removal ...
Gene Wengert-WoodDoc
It is virtually impossible to damage air dried lumber unless you add moisture back when you start the kiln or if you over-dry the lumber.
The daily rate of moisture loss varies depending on species and thickness. I have developed safe rates for hardwoods. For SYP, some kilns dry it in 18 hours. Other, less powerful kilns take 3-5 days. This gets nominal 2” material down under 20% MC. As the green moisture is around 100% MC, then 30% MC loss on day one means drying to 70% MC, day two down to 40% MC, day three down to 10% MC. The 30% MC loss a day is the maximum and some pieces will not be quite that fast.
As moisture meters do not work accurately until around 28% MC loss and lower, they cannot be easily used for measuring high MC moisture loss.
7/4/18       #4: safe rate for moisture removal ...
Thanks That is helpful. My testers came in the mail yesterday and my wood is 20% as expected. How long does it take air dry 1 inch pine wood to achieve the moisture content of its surrounding ( if you put wood in house shop etc and wait to use it)?
7/4/18       #5: safe rate for moisture removal ...
Gene Wengert
The speed of drying at low MCs depends on the relative humidity and temperature, as well as some properties of the wood including thickness, species and grain. So, it is hard to answer your question.
