Sawing and Drying
barn wood i.d.
12/26/19
george Member
trying to i.d.wood from 1860 barn northern maine.hemlock or chestnut,to heavy for pine spruce,to light for oak.
12/26/19       #3: barn wood i.d. ...
george Member
another pic
12/30/19       #4: barn wood i.d. ...
Keith Newton
Well, none of the images you posted would be Chestnut, which is ring porous.
Since it is a hard soft ring, it would be one of the softwoods. I would think your nose might help you separate those, and I would think Pine is heavier than Spruce.
1/5/20       #5: barn wood i.d. ...
GeneWengert-WoodDoc
Because you say "heavy" I suspect you have tamarack, also called American larch and norther larch. The color, transition from spring to summer is gradual, and it is durable.
2/25/20       #6: barn wood i.d. ...
Brendan Meyer
Sell it as-is. Or bag it in stripper. Heavy duty poly tubing from Uline. Soy Gel stripper from Franmar. Dwell 48 hours. Turn every 12 hours. Scrape, rag off excess, rinse with mineral spirits. Goop and rags in normal trash. No dust or sanding. Can re-use Soy Gel two or three times if you really want to.
2/26/20       #7: barn wood i.d. ...
GeneWengert-WoodDoc
Barn wood is almost always a locally available wood. Eastern white pine was wide, lighter in weight and widely available in the East. Where are you?
