Sawing and Drying
Wood Kiln Moisture Barrier
4/1/20
LionelBob Member
When installing a moisture barrier in the walls, floor and roof a dehumidification kiln, what are we trying to accomplish? Keeping the outside environment from entering the kiln or keeping the kiln environment from escaping to the outside environment.
4/1/20       #2: Wood Kiln Moisture Barrier ...
GeneWengert-WoodDoc
We are trying to keep the interior moisture from getting onto the insulation, where it would condense from a vapor into liquid and destroy the insulation value and even cause decay.
4/3/20       #3: Wood Kiln Moisture Barrier ...
TTalma
In the northeast we use foam sheets available at home centers for insulating and creating a vapor barrier when finishing our basements, can that be used or will it breakdown with the heat?
4/3/20       #4: Wood Kiln Moisture Barrier ...
GeneWengert-WoodDoc
The sheets from large stores often cannot go over 130 F. They deteriorate at hotter temperatures.
The sheets alone are not useful as a vapor barrier, as moisture can get around the edges. Special sealing is required for the edges when two panels join or the panel is in contact with wood framing.
I have seen each sheet inserted into large plastic bag to provide a vapor proof barrier for gthe sheets themselves.
There is the open and closed cell issue.
2/23/22       #5: Wood Kiln Moisture Barrier ...
Lucas Ross
Nice drawings and design. You may have to get a engineer or architect to sign off on it in order to get a permit depending on your location.
