Sawing and Drying
drying red elm
6/10/20
Bill Stuewe  Member
Website: http://www.billstuewe.com
I have some 24"+ diameter red elm logs to saw and dry. I plan to mill most at 10/4 and would it be better to air dry or solar kin this wood?
6/10/20       #2: drying red elm ...
Jessica  Member
Website: finecraftsmanlumber.com
You could air dry to get the moisture content down, but I would definitely finish drying it in a kiln.
6/10/20       #3: drying red elm ...
Bill Stuewe  Member
My concern is that the solar kiln might dry the elm too fast. Does anyone have experience with red elm and having it go crazy from drying to fast in a solar kiln? I will have about 1000bf, mostly 10/4
6/18/20       #6: drying red elm ...
John Member
Red elm is pretty tolerant and can be dried at the same rate as ash. With 8/4 stock the max. rate is 4.1% / day, but I don't know how much lower it is for 10/4. My guess would be around 3% max.
Fill the kiln, if possible, and monitor your samples to keep track of the daily rate of drying. If it's too high, close the vents and cover a portion of the glazing to slow down the rate. Good luck.
John
    • Forestry.com
