Sawing and Drying
pine/spruce logs
6/24/20
oakcutter Member
i have some white pine and white spruce logs 8"-12" that were cut a year ago that I would like to use as decorative ceiling beams in my new house. would it be necessary to dry these logs before hanging or can I let them dry naturally?
7/2/20       #3: pine/spruce logs ...
GeneWengert-WoodDoc
The safest answer is to dry them prior to using. If the dry in place, you might hav twisting or other warping, along with shrinking. Howe Er, many times they are dried in place.
1/5/21       #5: pine/spruce logs ...
Scott Alvik Member
Website: http://cabindoctor.com
cut into "cants" an inch larger than you will need. Better to have sit in a kiln but if you cant... Allow to sit that way indoors and check moisture after 30 days and when it drops down to 15% cut to final size and bring into heated space where they will live for 2 weeks. then install. may still twist and check a little over 2-3 years.
