Sawing and Drying
PPB fungus
11/16/20
Elia Bizzarri
Website: http://handtoolwoodworking.com
A couple days ago, someone mentioned that powder post beetles (I'm using the term loosely) bring a fungus (or was it a bacteria?) with them that weakens the wood surrounding the hole. Is that true? If so, how far beyond the hole is weakened? It probably depends...?...
11/17/20       #2: PPB fungus ...
Many beetles and other insects that bore into wood have a symbiotic relationship with fungi. The insect provides the fungi with the food source while the fungi converts the wood to a digestible form for the insect.
Often the fungal contamination is evident in the in the changed appearance of the wood. Spalting is the marbling effect and does weaken the wood. Often there are multiple fungi competing for real estate and you can see the borders of one another with different coloration and fibre damage.
11/18/20       #3: PPB fungus ...
Elia Bizzarri
Interesting! Thanks, Elia
11/19/20       #4: PPB fungus ...
Gene Wengert
Indeed, the ambrosia beetle, which is a PPB that prefers wetter wood, brings the ambrosia fungus with it when it lays the eggs and the fungus is a food source for the larvae when they first hatch. When the beetles exit the wood several weeks later, they drill a hole to the surface and the fungus then is deposited on this exit hole sometimes and makes the hole a darker color on the border or edges. The fungus does not weaken the wood, but certainly a bunch of small exit holes and the tunnels in the wood when the pupa and larva are active would weaken the wood. Other fungi certainly can weaken wood as they eat a wood component...white rot which causes spalting, and brown root fungi are two groups of wood destroying fungi. And some fungi, like blue stain have no important effect on wood strength as they eat on the sugars and starches in the wood and not the wood itself.
11/19/20       #5: PPB fungus ...
Elia Bizzarri
Fascinating!
To be more specific to my situation, I am building Windsor chairs with oak heartwood spindles that sometimes have powder post beetle holes. Is the strength loss just what the beetle removes, or should I be worried about fungal decay around the hole (besides any decay that I can see with the naked eye; i.e. spalting sapwood, etc.)
View higher quality, full size image (500 X 625)
11/19/20       #6: PPB fungus ...
rich c
The issue with true powder post beetles is not the tiny hole. It's the long channels in the wood under the surface. I've seen infested wood that you could break up with your hands. I would definitely not use that in thin spindle work. In fact most windsor chair makers rive the spindles out of the log so the grain runs the entire length and has the springy characteristic needed for the most comfortable chairs. And red oak can also be brash and brittle compared to woods like hickory.
11/19/20       #7: PPB fungus ...
Gene Wengert
I agree with rich c.
Brash oak will be found in slow growth wood (more than 7 rings per inch). Also brashness results when oak has been dried at too high a temperature (over 160 F) or down to a MC under 7.0% MC.
Even a few degrees of grain angle substantially weakens the wood. So, it is indeed critical that the dowels or spindles always be sawn parallel to the grain, the grain direction is determined by splitting a log and then sawing parallel to the split surfaces.
11/20/20       #8: PPB fungus ...
Elia Bizzarri
I understand all that. I rive my stock, shave it with a drawknife following the grain perfectly, use fast grown oak, dry it at 140F.
If I have a single powder-post beetle hole in the 5/16 diameter tip of a white oak spindle, do you think I should consider the strength loss to be the size of the hole, or is there a possibility that the wood surrounding the hole is weakened.
There are no major unseen tunnels beneath the spindle's surface, since the beetle activity ended when I made the spindle (I put the spindle in the kiln right after making them).
Thanks!
Elia
11/20/20       #9: PPB fungus ...
rich c
The hole you see is the exit hole. An egg is laid, the larva forms and works it's way into the wood to feed and grow. When it's mature it bores out of the wood and repeats the life cycle of mating and the females lays more eggs. If it's powder post beetle, there are ALWAYS channels under the hole, unless you were lucky enough to cut off all the tunnels and you only have the exit hole left. If you don't see channels anywhere, it's probably not PPB. The spindles could easily be tested if the hole causes issues with breaking a couple to test strength. Better to find out before shipping to a customer. As a caution, the center of the wood must reach a minimum of 133 degrees. Most kiln operators sterilize at 150 degrees to insure complete sterilization of the interior of the wood.
11/20/20       #10: PPB fungus ...
Gene Wengert
Have you ever looked at the floor joists from the basement. You see large holes where the wires go through, but these holes are halfway between the top and bottom of the joist. Put the same size hole near the bottom and you have serious strength loss. So, the multitude of tunnels can easily cause strength loss because of their location and the number of tunnels.. The fungus is not "eating the wood" so that is not an issue.
The ambrosia PPB can be avoided in drying by using good sanitation practices (no wood debris) and using recently sterilized stickers, 4x4, etc. in other words, we disrupt their life cycle and also the supply of new insects.
11/25/20       #11: PPB fungus ...
Elia Bizzarri
Thank you!
    • Forestry.com
