I just built a mini version of a VA tech solar kiln (4’ x 2.5’ by 2.5’ ). I did it completely out of scrap material! I only had to buy screws and two small fans! I am “turning it on” tomorrow. I gather 2 to 4 feet long local logs from neighbors and arborists and make bowls, boxes, vases, puzzles, pepper mills, and whatever looks interesting. I work with many local woods.
Three questions at this point:
1. Since this is a small kiln with a roof angle of 33 degrees (I live in North Texas) – it is a good idea to tilt it 10 or 15 degrees back in May June, July and 10 or 15 degrees forward in Nov, Dec, Jan? Is it worth putting the kiln on a large lazy susan to track the sun? I realize that this would not work for a full size kiln, but mine is small/light enough that I think I can figure it out, but is it worth it?
2. I want to dry fairly thick wood blanks. Like 3” x 3” x 7” for pepper mills, 4”x4”x12” for turning projects and 7”x5”x4” for boxes (I use the bark edge as the top, these can’t be made from store bought 4/4 lumber). I don’t care how warped or cracked the get during the drying process – I will joint/plane them into rectangular blocks and cracks get enhanced with colored epoxy later. But they must be dry all the way through (or they warp when they are worked). Any advice on drying thick, but small, blocks of wood? I will be mixing these thick blanks with 4/4 boards – any issues with mixing different thickness woods in a mini kiln? Any issues with mixing different types of wood in a mini kiln (beside the issues with mulberry, osage orange and black locust mentioned in another post). I use pecan, walnut, mesquite, lace bark elm, ash, hackberry, bradford pear, chinaberry, post oak, cottonwood and sycamore. Note: I turn all my bowls green and will not be using the kiln to dry bowls.
3. Any other issues I may run into with a mini kiln?
Thanks in advance for any advice.
