Sawing and Drying
Anchorseal Effectiveness in Cold Weather
1/31/22
Mark Rodriguez
Will Anchorseal work as required in temperatures below 32 degrees Fahrenheit to seal log ends?
1/31/22       #2: Anchorseal Effectiveness in Cold We ...
MarkB
No. Its wax based. In warm weather it barely penetrates deeply so even if you keep the pails warm when the material hits an ice cold log end its pretty much game over. Your bonus is in the dead of winter things dry a bit more slowly anyway so you have a bit more time but Anchorseal in freezing temps will basically just sit of the surface.
1/31/22       #3: Anchorseal Effectiveness in Cold We ...
You should call UC Coatings and talk to them. They have a glycol formula and another called a winter formula of the Anchoseal 2.
https://uccoatings.com/products/anchorseal-2/
2/1/22       #4: Anchorseal Effectiveness in Cold We ...
Mark Rodriguez
thank you for the information!
2/4/22       #5: Anchorseal Effectiveness in Cold We ...
GeneWengert-WoodDoc
It is correct that there is a winter formula. However, if the log end has some water that came out and then has frozen, or rain or snow, you will be coating the water and not the wood itself. The coating will fall off when the snow or ice melts. Similarly, you cannot coat a muddy end.
As the freshly sawn end of a log is rough, there are lefty of places for the waxy film to attach even in the winter, below freezing.
3/16/22       #6: Using E. Globoidea for log cabin ...
Stefan Seitzer
Website: http//www.maungaiti.com
Hi there
I have have grown a stand of E. Globoidea in NZ from seedlings and they are now 25 years old.
Average dbh is about 400mm
I am wondering if the logs could be used for a log cabin and if anyone has had experience with this species
Any comments are appreciated
Best wishes
Stefan
3/16/22       #7: Anchorseal Effectiveness in Cold We ...
GeneWengert-WoodDoc
The eucalyptus species are known to have a lot of stress in the trees, so that when is cut, it immediately has several large splits at the end of a log. I am not sure about your specific species. The splits lengthen as the log dries. Further, some species have spiral grain in the first 15 years of growth, and it seems worse with plantation trees, so that they twist in drying, so they cannot be used for cabin logs until they are quite dry.
Are there any log cabin manufacturers or even sawmills in your area that can share their experiences with warping of logs or lumber?
