Sawing and Drying
RE: 300+ Year Old Oak Tree
1/31/22
Kenneth
We have a 300+ year old oak tree, which is 5 to 6 feet in diameter.
Is there a sawmill that could cut this tree? We would prefer a bandsaw mill versus a chainsaw mill.
1/31/22       #2: RE: 300+ Year Old Oak Tree ...
You are asking about purchasing a saw mill to cut 1 tree?
2/1/22       #3: RE: 300+ Year Old Oak Tree ...
Captain Obvious Member
No. He is asking if there is a mill that would cut the tree for him since the tree is 5'-6' diameter; he is concerned it is too big to fit in a mill.
2/2/22       #5: RE: 300+ Year Old Oak Tree ...
Where are you located?
2/4/22       #6: RE: 300+ Year Old Oak Tree ...
GeneWengert-WoodDoc
There are ways to turn the log to cut it, even when it is larger than normal. However, the weight is an issue. Such weight can damage log holding equipment and log turn equipment. So, most mills would halve the log or even quarter it. With this approach, you can also create a lot of quartersawn lumber, if you wanted. There can be some very wide pieces, which must not be too wide for subsequent processing.
2/8/22       #7: RE: 300+ Year Old Oak Tree ...
If you just want to know if there is a sawmill that cuts that big, then the answer is yes. 67" capacity
https://www.hearnehardwoods.com/about-us/
2/8/22       #8: RE: 300+ Year Old Oak Tree ...
There also this option.
https://www.youtube.com/watch?v=vODXyUmkEoo
