Sawing and Drying
Sawmill help. (Cutting on an angle)
8/4/22
DC Member
Hi guys. New here. Hoping to find some answers. I have an American mills circle sawmill powered by a tractor pto. The pto turns opposite of the design of the mill. I reversed the blade. It cuts well but seems to be cutting crooked. The beginning of the board ends up thinner and the end of the board after it comes out of the cut is fatter. Would that be caused by the blade being dished in the wrong direction because I reversed it? Any help appreciated!
8/7/22       #3: Sawmill help. (Cutting on an angle) ...
Have you measured the bed to make sure it is parallel to the blade? The log stops are also parallel? I can't imagine a situation when the direction of feed would disturb the body of the blade. Is there evidence of curls coming off the back of the blade when it exits the log? Lots of resonance off the blade when free spinning? Same cut quality all the way through the log?
    • Forestry.com
